ip listen ports
Discussion in '3CX Phone System - General' started by wbhst, Jan 24, 2009.
  1. wbhst
    Jan 24, 2009
    Greetings all,
    Just installed 3cx free edition. My server has 3 ip addresses (interfaces). I also run other main SIP server on 1 of these interface port 5060.
    When I installed 3cx on the same server it starts listen all interfaces (IPs): 0.0.0.0 port 5060. So my basic SIP server stopped working on 1 interface.
    How to configure 3cx to listen on just 1 interface?? Can't find this option(((
    p.s. 3cx www config using ajax is very slow:( it's better to code simple html or use server side soft for admin panel.
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    This has never been tested. It would be ideal to move one or the other application to a separate or virtual machine
  3. wbhst
    Jan 24, 2009
    btw all server software normally must have settings for IP listen interfaces :shock:
