IP of Phone is incorrect
Discussion in '3CX Phone System - General' started by Grimbergen, Feb 18, 2015.
  1. Grimbergen
    Feb 18, 2015
    Hi all,
    I have a SNOM 300 which is showing in System Manager > Phones as having an IP address which is no longer correct. It had picked up the incorrect IP from another phone which it was slaved from and was using the phone's DHCP. Having corrected the settings on the phone it was connected to so it now passes on DHCP requests, the phone now has a suitable IP, but no calls can be routed to it as the system hasn't registered it's new IP. I have tried re-registering the phone but it hasn't made a difference.
    We're running 3CX Version 12
    Snom 300 is firmware 8.7.3.25
    Server log showing call from me to 453 with the wrong IP - 192.168.26.2:
    18-Feb-2015 12:32:24.016 [CM503008]: Call(C:3416): Call is terminated
    18-Feb-2015 12:32:24.016 Leg L:3416.1[Extn] is terminated: Cause: CANCEL from 172.60.0.91:2048
    18-Feb-2015 12:32:15.949 [CM503025]: Call(C:3416): Calling T:Extn:453@[Dev:sip:453@192.168.26.2:2048;line=g8onwvvv] for L:3416.1[Extn]
    18-Feb-2015 12:32:15.900 [CM503027]: Call(C:3416): From: Extn:881 ("Me" <sip:881@172.60.0.1:5060>) to T:Extn:453@[Dev:sip:453@192.168.26.2:2048;line=g8onwvvv]
    18-Feb-2015 12:32:15.900 [CM503004]: Call(C:3416): Route 1: from L:3416.1[Extn] to T:Extn:453@[Dev:sip:453@192.168.26.2:2048;line=g8onwvvv]
    18-Feb-2015 12:32:15.899 [CM503001]: Call(C:3416): Incoming call from Extn:881 to <sip:453@172.60.0.1:5060>
    If anyone knows how I can get the system to recognise the phone's current IP, then I would be very grateful.
    Many thanks,
    Grimbergen
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
    Please restart Phone System if possible.
    After that reconnect the Snom and check if it has the right IP-address.
