IP Phone Configuration features - Call Completion on Yealink Handsets
Discussion in 'Ideas' started by jj1, Aug 17, 2017.
IP Phone Configuration features - Call Completion on Yealink Handsets 5 5 4votes
5/5, 4 votes
  1. jj1
    jj1
    Feb 23, 2012
    24
    Call Completion is a great feature on Yealink handsets however we currently have to manually modify the provisioning template to enable it.
    It would be great to see this turned into an IP Phone configuration option in the management console (Like Transfer Type and other settings are in v15.5 SP1), perhaps you could squeeze this in to Service Pack 2.
    For those who have not used it:
    Call Completion on Yealink handsets means that during an internal call, if the callee is busy, the caller is prompted whether he wants to "wait" for the other extension to become available again. As soon as it is, he is notified and can initiate a call. This feature is often described as "callback if busy".
  2. jj1
    jj1
    Feb 23, 2012
    24
    Just to clarify this is the configuration option we would like to be able to set from the 3CX Management Console
    #Enable or disable the call completion feature; 0-Disabled (default), 1-Enabled;
    features.call_completion_enable = 1
    #2 jj1, Sep 25, 2017
  3. jj1
    jj1
    Feb 23, 2012
    24
    Any chance this could make it into V15.5 Update 5? I can see that you have added template support for a 2nd Sidecar on the Yealink T4X handsets in v15.5 Update 5 Beta
