IP Phone GrandStream & 3CX
Discussion in '3CX Phone System - General' started by SBDTel, Feb 5, 2018.
  1. SBDTel
    Feb 5, 2018
    Hi all,
    I have case config device ip phone GrandStream Model 1610 with 3CX System, specific information is as follows:
    • I configured the extension 1060 to ip phone device and softphone
    • IP Phone & SoftPhone connect to 3CX System via internet
    • IP Phone & SoftPhone call and receive calls from extension other ==> OK.
    But:
    • From SoftPhone call outbound ==> OK
    • From IP Phone call outbound:
      • IP Phone display: 404
      • Logs on system 3CX:
        • [Flow] Target endpoint for 0972648405 can not be built!
        • Call(C:540): Call to <sip:1060@system.xfone.vn:5060> has failed; Cause: 408 Request Timeout/INVITE from local
    Please support me,
    Thank you,
    10,754
    286
    If the GS set can call other extensions, and the only issue is with external calls, then there may be a problem with outbound rules, and specifically how they deal with the number(s) being dialled. This should affect calls from all sets if they are dialling the same number(s). Check the 3CX Activity Log.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @SBDTel
    Like leejor mentioned, can you call other extensions or is the issue only with outbound calls?
    Also is the grandstream phone manually provisioned as a remote extension?
