ip phone provisioning
Discussion in '3CX Phone System - General' started by Heath, Aug 13, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    122
    I have Aastra Phone that I am trying to provision... I went in to extension and added the phone and gave me the provisioning link... I then clicked on how to provision this phone... Now it says find your provisioning folder of your 3cx install, and save the firmware in that folder.. Its giving me info where to look for the folder on a hard drive, but my 3cx is stored on OVH Linux servers... And when I put the config file information in the webgui of my phone, nothing... ALso in the Management console even though I added the phone to the extension.. There is nothing on the Phone Tab, and when I click add phone, it goes to the same place where I added the phone in extensions.
  2. us1
    us1
    Oct 19, 2015
    80
    21
    You will need to SSH into the OVH server. You can use SCP to transfer any firmware as needed.
    That said, you will note the Aastra phones are considered "legacy / limited feature set and support". Based on your other posts, it appears you're diving into 3cx for the first time. It helps tremendously to use only the supported phones, hardware, SIP trunk providers, etc., in order to make this a great experience. Going outside of those recommendations when you're still so new to the platform will make it exceedingly difficult to succeed.
    Best of luck!
  3. Heath
    Heath New Member
    Aug 12, 2017
    122
    The aastra phones is what I currently have with my current provider. I'm converting to 3cx. I'm not much savvy on Linux servers. I have putty and now how to log in to the cloud. But that's much it. Any help is much appreciative.
  4. AlexDBarrett
    Jan 25, 2011
    71
    9
    Hi Heath,
    Have you considered in buying some tech support time?
