IP Phone Recommendation
Discussion in '3CX Phone System - General' started by rudym, Aug 15, 2008.
  1. rudym
    Aug 15, 2008
    36
    Hi all,
    Hoping someone can help, I'm kind of new to the VoIP world and trying to setup a new 3CX system. Can someone recommend a good phone I will have 8 lines and about 16 ext. some of the features i would like to have are all forwarding, transferring, voicemail, call conferencing and anything good that caomes along :lol: . Any help would be greatly appreciated.
    RudyM
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Recently I installed 50+ phones on the plant. I used Grandstream GXP 2000 + 2000EXT for secretary, GXP-2010 for management and GXP-1200 for employes.
    Also I used 2 GXW-4108 FXO gateways for old analog lines, some HT-502 for fax machines, 1 Portech MV-304 (4 port VOIP-GSM) gateway, 1 Patton Smartnode E1.
    All works surprisingly smooth. The sound is excellent. I would recommend Grandstream.
    The only problem I stuck with is a good Wi-FI SIP phone. I cannot found one.
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    you forget linksys also
    in my openion go ahead gxp2020
    it's good voice and quality
    but you in overall compare the are equale
  4. igor.snezhko
    Jan 7, 2008
    668
    7
    Im not found gateways at Linksys. So I prefer to take equipment from single vendor and receive discount. In addition the Grandstream GXP-1200 is cheaper than Linlsys analog.
    I used some GXP-2020 but preffered GXP-2010 for mass installation. GXP-2010 contains large additional keypad for direct dialing or BLF. GXP-2020 is bigger but less useful.
  5. radelman
    Feb 21, 2008
    60
    I am using 6 Grandstream 2010's which produce clear tx and rx. I am also using a Grandstream 4104 for connection to pstn's and have suffered no major problems. These phones do not however record calls.
  6. ktikoft
    Jun 22, 2007
    59
    I have GXP2020's as the 2010s were not around at the time I agree the 2010 is the pick up the bunch espcially now 3cx has conferencing. I will be happier when there is a meeting security interface for the conferencing module.
    Snom are better in my opinion but you do pay for it. witha 15-30 % premium
  7. moon1234
    Jan 25, 2008
    24
    Polycom are by far the best for voice quality. Look at the 550s or 650s. You will not be sorry.
  8. h2009
    h2009 Member
    Mar 15, 2008
    447
    For a good combo of both sound quality and price - Aastra is the way to go. IP55 are the best all round phones i've used and i've tested just about everything on the market.
    PM me if you need help and your in the UK or if your going to be terminating alot of calls to the UK.
