ip scheme for ip pbx exchange
Discussion in '3CX Phone System - General' started by ameyambekar, Dec 20, 2012.
  1. ameyambekar
    Dec 20, 2012
    hi everybody ,
    i have a genuine problem . my office runs on following ip scheme 133.68.1.0. however i would like to run the 3cx exchange on the same ip scheme ie 133.68.1.0 (255.255.255.0). how do i configure the exchange .please help me ... its urgent...
  2. SmackBangGollop
    Nov 1, 2012
    9
    were going to need some more information. I'm not exactly sure what the problem is
  3. ameyambekar
    Dec 20, 2012
    hi
    thanx for the reply. let me elaborate the problem . when i put the ip scheme of the ip phones and the pc on which ip exchange is installed as 192.168.100.0 (255.255.255.0) and so on .the ip phones get registered easily . but the problem starts when i change the ip scheme of the ip phones and the pc on which ip exchange is installed to 133.68.1.0(255.255.255.0)and so on ,the ip phones do not get registered in the exchange . how do i resolve the issue ...please help
  4. leejor
    10,565
    245
    Is everything else, on the network, in the same IP range (133.68.1.XX) ? This would, of course, have to include the gateway (to the WAN), and a DHCP server. As long as all devices use the same IP range (with the subnet mask you are using), then there should not be an issue. Are you giving the sets static IP's or are they picking those up from a DHCP server?
    Private networks usually use 192.168.XX.XX, 10.0.XX.XX or 172.16.XX.XX
  5. ameyambekar
    Dec 20, 2012
    hi,
    thanx for the reply. my complete office complex is working on the same IP scheme ie 133.68.1.0 (255.255.255.0). all the clients in the network have static ip and there is no dhcp server . i have a doubt , is it that 3cx exchange(free version) works only on a specific set of ip scheme.can you please help me on this .
    regards
    amey
  6. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    Am uncertain, but you might take a look at Windows firewall.
    If the server running 3CX only has one NIC card and it is set to the same subnet as the rest of the network and phones and there is no Vlan or other oddity about (all one homogeneous network), then as Leejor indicated it should present no problem. You should be able to ping from the server to any device (where ping not blocked) without issue.
    You should run the firewall checker first as this may give a clue and additionally check to see if perhaps 3CX blacklisted any of the IPs of interest. Finally, simply turn the Windows firewall or other firewall that may be in place on the server off for a bit and see what happens.
  7. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Adding 133.68.1.0/24 as private network in custom parameters (advanced settings) in 3CX maintenance console should do the job.
    Regards
