iPad Client popup
Discussion in 'iOS' started by petewatterschats, Apr 2, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Unless the 3CX Client is displayed can not see an incoming call.
    Phone is not locked and looking at another application, the 3CX client does not Pup up
    If the iPad is locked the 3CX client does not pop up or any notification
    is there a way to fix this
    11,113
    329
    You have asked this question previously and there are a number of posts dealing with the same sort of issue. You don't say whether or not you are using PUSH notifications.
    See....
    3cx-app-in-iphone-is-not-responding-41872.html
