Iphone 4 lost registration
Discussion in 'iOS' started by glimmer1980, Aug 15, 2012.
  1. glimmer1980
    Jun 12, 2012
    Hi all,
    I have a Iphone 4 with 3CX installed (latest version). Now i have SIP account active. Now we use 3CX internally on our WIFI network and it happens that i get a message from 3cx saying:
    LOST REGISTRATION, NETWORK AVAILABLE LAN
    What happens is that i can't receive calls if i receive this message. Does anyone have any clue on what this could be?
    Regards,
    Ramon
    10,583
    251
    This cropped up previously, but was supposed to be corrected in a new release...
    http://www.3cx.com/forums/iphone-unregister-without-notifcation-27521.html
  3. glimmer1980
    Jun 12, 2012
    I'm affraid the new update didn't fix this problem, i hope that the next update will.
    When will there be a next update?
  4. leejor
    10,583
    251
    Your guess is as good as mine, you'll just have to keep checking back.
    Someone at 3CX may be kind enough to provide some Info on when that might be.
  5. roars1111
    Aug 31, 2012
    There is a limitation on how apps work in the "Background" in iOS. When a running application is pushed to the background in iOS4 or higher, it is put into a suspended state. It is not actually ‘running’ any more. Because the app is in a suspended state, it won’t impact the performance of an application running in the foreground nor will it consume a lot of battery. More importantly, for a VoIP application like 3CX for iPhone, the application cannot perform any actions for a minimum of 600 seconds. This means the app cannot perform any SIP registrations, keep-alives, or other actions that a VoIP application normally executes in order to maintain connectivity. Apple did provide support for the maintenance of TCP-based connections for VoIP applications while in the background however. Try switching to TCP transport if your PBX support it.
