Iphone 4 Will not register?
Discussion in 'iOS' started by zone97, Jun 8, 2011.
  1. zone97
    Dec 12, 2010
    11
    Device Info
    Phone Model: [iPhone]
    Generation: [4]
    Firmware Version: [4.2.1]
    Jailbreak: [YES]
    Cydia Installed: [YES]
    Issue Info
    Handset: [Iphone]
    Contacts: []
    Connection: [3G]
    Server: [External]
    I have been following the guides and posts here on the site but can not seem to get my phone to register externally. It will via wifi internally. I have had it work before via vpn, but would rather a direct connection as the vpn often drops and then the phone will also.
    Is there a guide for manual setup using the iphone externally?
  2. StefanW
    Jun 2, 2009
    1,210
    84
    Does your PBX has correct NAT settings? In Case of a 3CX 5060 and 9000-9049
    Keep in mind there lots of Providers Blocking VoIP.
  3. ricaluanna
    Jun 29, 2011
    It worked fine on my iphone4. Wonder what went wrong with yours?
  4. willow
    willow Member
    Mar 1, 2011
    471
    i would assume that your carrier may be blocking 5060 port. I just tested my iphone 4 in the states over the 3g network and it works fine.
  5. harolddwell28
    Jul 1, 2011
    wondering myself
  6. willow
    willow Member
    Mar 1, 2011
    471
    also make sure that your public IP is populated in the 3cx server under settings/network/public ip. You will need to restart the 3cx service after the change.
  7. zone97
    Dec 12, 2010
    11
    Ok here is where I have gotten thus far..
    I can get the phone to register, but the person I call from the iphone can hear me. I can not hear them. Works fine internally but not externally (3g). I have tried the 3cx app and Bria, both do the same thing. When connected internally via wifi works fine? Any suggestions?
  8. willow
    willow Member
    Mar 1, 2011
    471
    sounds like you have a nat issue and dont have ports UDP 9000 thru 9049 forwared from the router to the 3cx system. remember when the 3cx app is started outside the network it uses different rtp ports then inside the network.
  9. zone97
    Dec 12, 2010
    11
    I have 5060 and 9000 -9049 tcp/udb forwarded. should I just make it udp only? would that help?
  10. willow
    willow Member
    Mar 1, 2011
    471
    the rtp ports should be udp only. also make sure that no other services on the router are using those ports. It may be useful to have have the pbx delvier audio activated on the 3cx console for the extension.
