iPhone 5 iOS 8 not ringing
Discussion in 'iOS' started by gabnunez, Oct 7, 2014.
  1. gabnunez
    Oct 7, 2014
    I have 3CX 3.0 in my iPhone, it connects to my Asterisk PBX and works ok, but it doesn`t ring when receiving calls. If i upgrade to v12, it doesn't connect to my PBX. How can I solve this?
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    First.. can you originate ("make") calls from 3CXPhone?
    Second.. is the app "open" on the phone? You need push notifications if the device was locked or if the app was changed to something else.. which leads to a needed update which is pending.
