Solved iPhone app not pushing
Discussion in '3CX Phone System - General' started by rslattery, Jul 10, 2017.
  1. rslattery
    Dec 20, 2016
    12
    I have a number of users who cannot receive calls unless the app is open and on screen. The push feature did work at one point and works fine on android.
    So what changed iOS or the app?
    This is critical for some user for it to be working. Please help!
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    What version of 3CX ?
  3. rslattery
    Dec 20, 2016
    12
    Version 15.
  4. teldata1
    Aug 24, 2015
    63
    I assume it's already enabled but doesn't hurt to check: Do you have "Enable PUSH for smartphones" turned on, in the Phone Provisioning page of the extension?
  5. rslattery
    Dec 20, 2016
    12
    Is that on the app itself or the console?
  6. rslattery
    Dec 20, 2016
    12
    I do not see any options for push in the Provisioning section of the extension in the console.
    http://imgur.com/a/r6JUC
  7. teldata1
    Aug 24, 2015
    63
    Just above that section, drop down the "Your phones" tab and select 3CX Client. The Enable PUSH for smartphones will appear at the bottom now.
  8. rslattery
    Dec 20, 2016
    12
    Hi yes push is enabled, is there anything on the iphone that has to be done like the andorid app?
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    i had to reprovision recently.
  10. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,401
    280
    Please check that the latest IOS certificate is downloaded from the updates section of the management console and if not please download it. Once you do please send new welcome emails to the clients and reprovision the devices
  11. rslattery
    Dec 20, 2016
    12
    This worked, thank you!
