Iphone as external extention with no sound
ndalikan
I have configured an iphone to connect to the PBX.
When with in my WLAN, everything works fine. But when I am outside, either on another wlan or on 3G, I can connect but I have no sound.
Any ideas what can be wrong?
Thank you,
NDA
This sounds like network issues. Does the party outside hears u but you dont hear?
Then the issue is
1 Wifi) you have no NAT in the Firewall to Frwd SIP and RTP to the IP of the iPhone
2 3G) Ur Provider blocks VoIP Calls.
http://www.3cx.com/forums/every-new-post-must-contain-18726.html
I would recommend forwarding port 9000-9049 to the 3cx. Also check and make sure that your router does not have a sip alg running. I have seen netgear routers with sip alg do weird things to the sip rtp.
Getting Started - Admin
AmirLD
Get 3CX - Absolutely Free!
3CX
