iPhone client issue when calling external number
Discussion in 'iOS' started by XcamaroX, Mar 22, 2017.
  1. XcamaroX
    Aug 25, 2015
    26
    My iPhone works fine via 4G and WiFi if I make calls to our internal extensions, but when I try to dial an external number, for example my friend's number, or my house, when I type the number and press on dial, it hesitates for a millisecond and it takes me back to dial the number. If I dial an extension it works fine.
    It does this from the WiFi AND the 4G connection. The phone is On Hook (green) and Available.
    Any help will be appreciated.
    Thanks!
