Iphone directly connected to Public IP ?
Discussion in 'iOS' started by dlazure, Jan 15, 2013.
  1. dlazure
    Nov 5, 2012
    65
    hi guys
    is it possible to connect the iphone app directly to the Public ip of the 3cx phone system or we weed the tunnel or the sip proxy manager... because the tunnel app is always disconnecting
    thanks
  2. StefanW
    Jun 2, 2009
    1,163
    74
    you can use the "SIP Account".
    this will register to the external ip in the account and will analyse the iphones public ip/port via stun to set correct contact
  3. dlazure
    Nov 5, 2012
    65
    thanks
    using sip account with the external ip address works better than the tunnel as it always disconnecting
    anyone had this issue?
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    An external extension I've found to work way better than using the tunnel more often than not.
