iPhone is connected but...
StevenM
Hi there
I have put all the settings in removed stun server as we use public ip address. It seems to connect as i receive calls but it keeps coming up as Not Connected and Presence and Contacts doesnt work. It happen inside and out side the company. I have all the correct ports open etc.
ok got it to work by email me the config but its really weird cause i had the same settings.
The only issue i have now is i cant get CTI to work with macbook. It rings fine but doesnt hangup properly
Hi Steve,
Please note that CTI is available only on 3CX Phone for Windows at the moment.
Regards
I just experienced the same as StevenM. Email config worked but manual doesn't. Support any ideas here?
thanks.
thanks.
I guess this post will clarify the difference between manual/welcome email created accounts (it applies to both MACOS/iOS)
http://www.3cx.com/forums/troubleshooting-3cxphone-for-mac-mic-problem-40444.html#p166467
Hope it helps
vali
Get 3CX - Absolutely Free!
3CX
