iPhone one way audio
Discussion in 'iOS' started by AndrewB1975, Mar 8, 2018.
  1. AndrewB1975
    Mar 8, 2018
    We have an iPhone which has developed a one-way audio problem but only when out of the office. Other iPhones and Android using the same account work. Is there a setting on the device which would cause this?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    The most common reason for this behavior is a different WiFi/3G - I mean, yes, all devices uses the same account, but each of them choose a local network. Usually, enabling tunnel in account settings should solve the problem.
