iPhone softphone 3cx ver.15 time out continuous 4g and 3g
Discussion in '3CX Phone System - General' started by perdicaro, Feb 2, 2017.
  1. perdicaro
    Jun 1, 2013
    26
    I installed properly 3cx, while monitoring the firewall the doors are all open, only the 80 and the 443 that I leave closed for safety; installed 3CX for iPhone and it works both outgoing and incoming, but the display alternates the message connecting / time out, why? how can I fix this problem? if i connect iphone to the wifi i see ready
  2. MRM
    MRM
    Dec 21, 2016
    53
    Please check the following :
    : https://www.3cx.com/docs/configuring-apple-push/
    Step 3 Firewall Configuration
    Push providers, iOS devices, and Mac computers are often behind firewalls. To send push notifications, you will need to allow inbound and outbound TCP packets on port 2195. To reach the feedback service, you will need to allow inbound and outbound TCP packets on port 2196. Devices and computers connecting to the push service over Wi-Fi will need to allow inbound and outbound TCP packets through port 5223.
    The IP address range for the push service is subject to change. The reason being that providers will connect by hostname, rather than IP address. The push service uses a load balancing scheme that yields a different IP address for the same hostname. However, the entire 17.0.0.0/8 address block is assigned to Apple, so you can specify that range in your firewall rules.
  3. perdicaro
    Jun 1, 2013
    26
    i open port 2196, 2195, 5223 but notting don't work same problem; about the link the you give to me, i don't have any "configuring-apple-push" opzion in 3cx ver 15
  4. MRM
    MRM
    Dec 21, 2016
    53
    This was more to do with the ports open than the push feature, did you restart the pbx services and the phone?
  5. perdicaro
    Jun 1, 2013
    26
    yes i do now, i reboot the pbx and iphone, same don't work
  6. MRM
    MRM
    Dec 21, 2016
    53
    Who is your provider?
    Also, try to reprovision your client if this will not help, from the management console run the Firewall checker.
    Let us know the results.
    #6 MRM, Feb 2, 2017
  7. perdicaro
    Jun 1, 2013
    26
    i check the firewall test are OK, and i reinstall and reprovisoring problem same
    #7 perdicaro, Feb 3, 2017
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,315
    531
    From your description i can see that you can not even register your client outside your network
    Which http/https ports did you use during the installation? Is tunnel enabled for the 3cx client? You can check this by navigating to the extension with the client provisioned / Phone provisioning/ Select 3CX client/ and check if tunnel is enabled. if not then enable it and send a new welcome email to the client.
  9. perdicaro
    Jun 1, 2013
    26
    for install i used 5000 from LAN; yes tunneling are enable
  10. perdicaro
    Jun 1, 2013
    26
