Iphone TLS connection
Discussion in 'iOS' started by klm, Dec 13, 2016.
  1. klm
    klm
    Nov 29, 2016
    20
    I try to push certificate to my Iphones for established TLS connection between the 3CX Iphone soft and 3CX server.
    I installed the certificate in the Iphone profile but the Client refuses to established the connection.
    Do you have a method ?
    Thx for your help.
    Regards
  2. andreasc
    andreasc Guest
    Hello klm,
    Please rename the Certificate extension to .3cxcert
    Attach the Certificate to the email and send it to the the Phone.
    You will be able to open the certificate with 3CX Phone Client.
    Let me know if that works for you.
  3. klm
    klm
    Nov 29, 2016
    20
    Hello Andreasc,
    I try but same issue, i open the cert : sip.3cxcert with my iphone and copy it to 3CX client.
    Status of SIP software : Not Registred.
    Thx for your help :)
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    My advice is to wait for the next-next release (I mean, not the one we already submitted to Apple and expecting to be released today or tomorrow). We found meantime some issues related to iOS 10 so that release will contain these fixes. We will announce it anyway.
    vali
  5. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi @klm
    As I said, we just released a new BETA version, 15.2.4.118, so, if you're a member of our iOS BETA program, please try again to see if now it's working.
    Regards
    vali
  6. klm
    klm
    Nov 29, 2016
    20
    Hi Vali,
    Release 15.2.4.122 same error "Not Registered"
    I downloaded the certificate on my iphone and change the name : cert.3cxcert
    Can you help me ?
    Thx
    Eric_Tii likes this.
