Solved iPhone X Screen
Discussion in 'iOS' started by ctni, Nov 9, 2017.
  1. ctni
    Feb 21, 2013
    26
    Are there plans to fully support the new iPhone X screen so the 3CX client takes advantage of the new screen size (full screen)?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    One of our registered beta testers just provided us some screenshots about how 3CX 15.2.8 is looking on his iPhone X - there are few UI fixes to be made, but overall it looks OK (and we're told is also working OK).
    dan_tx likes this.
  3. ctni
    Feb 21, 2013
    26
    Just installed the new iPhone app...it looks great on the X now.
    Vali_3CX likes this.
  4. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Much of credit for this goes to our iPhone X beta testers - really, they helped us a lot with screenshots and feedback.
  5. Ben Eubank
    Jul 10, 2017
    6
    @Vali_3CX Is it possible to become a beta tester?
  6. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi Ben
    Sure, of course you can. Only please send me by PM your Apple ID (the one in your device/Settings/ITunes & App Store).
    Thanks for help!
    vali
  7. Vali_3CX
    Dec 12, 2008
    1,527
    71
    A screenshot.
