IPKall Inbound rule
Discussion in '3CX Phone System - General' started by phuza, Jan 14, 2010.
  1. phuza
    Jan 14, 2010
    i have succesfully setup IPKall to route to my voipraider account. the 3cx softphone work like a charm. now i am trying to use it as the inbound number for my 3cx serer. the outbound works fine,but inbound does not. normally it seems you will use a DID number for inbound but with voipraider and IPKall it seems to be a random number. the only thing that seems to be consistent will be the ip from ipkall that will route the call by recognizing the ip will be greatly appreciated.
  2. phuza
    Jan 14, 2010
    As an Update I used a softphone with debugger to show what is shown when I call the IPKall number associated with my voipraider.com account.
    INVITE sip:phuza11@192.168.1.8:5060;line=a420a5a8278ca19 SIP/2.0
    Via: SIP/2.0/UDP 77.72.169.129:5060;branch=z9hG4bK21613a7065d34f558c34dab3cbe10012
    From: "8321234567" <sip:8321234567@sip.voipraider.com:5060>;tag=120113ac4af9ca8910340cb
    To: <sip:phuza11@69.153.202.33:5060>
    Contact: sip:8321234567@77.72.169.129:5060
    Call-ID: c633c621101a475b99112b270c9c1962@77.72.169.129
    CSeq: 3 INVITE
    User-Agent: (Very nice Sip Registrar/Proxy Server)
    Allow: ACK,BYE,CANCEL,INVITE,REGISTER,OPTIONS,INFO,MESSAGE
    Content-Type: application/sdp
    Content-Length: 296
    I used a Generic SIP Trunk to create my gateway. I can succesfully make calls so it must be something on the Inbound Parameters that need to be updated to specifically identify where the call is coming from. The server do ot even see any incoming calls. I called from my cell phone to my IPKall number so if someone can assist i would really appreciate. What I figured out is the IP 77.72.169.129 belongs to the owners of Voipraider ie Betamax. They own the IP range of 77.72.169.0-77.72.169.255 so any call coming from any of these IP's need to be included in the inbound parameters.
