Solved iptables: unknown option "-j"
Discussion in '3CX Phone System - General' started by complex1, Mar 14, 2017.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    790
    45
    I want to Implement QoS for 3CX VoIP on Debian Linux as described here:
    https://www.3cx.com/blog/voip-howto/qos-linux/
    I use this command:
    iptables -t mangle -A OUTPUT -p udp -j DSCP --set-dscp 56
    but get this message:
    iptables v1.4.21: unknown option “-j”
    Try ‘iptables -h’ or ‘iptables –help’ for more information.
    What am I doing wrong?
    Can somebody please help me to solve this?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @complex1
    Just tried now and it works on my machine and all i did was copy and paste it. Please check your syntax and try again as this should work.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Perhaps certain OS or browser will alter dash -?:confused:
  4. complex1
    Jan 25, 2010
    790
    45
    Hi YiannisH_3CX
    Thank you for the reply.
    I had copy / paste the command line because it was the easiest way, so I didn’t know why I got the error message.
    Now I tried it again by typing the command character by character, and it will accept it.
    Sorry for the noise.
  5. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Glad to hear it worked :)
