ipv6 Support for remote extensions
Discussion in 'Ideas' started by dig1234, May 17, 2016.
ipv6 Support for remote extensions 5 5 1votes
5/5, 1 vote
  1. dig1234
    Jun 1, 2015
    75
    This would eliminate the NAT problem entirely.
    Most ISP's fully support IPV6.
    It would be a huge win for businesses with small/medium remote sites.
    I would much rather support ipv6 than the headache of NAT..
  2. Phatanasak
    May 18, 2016
    It is this knowledge that is useful to the reader. I get quite a lot of knowledge.
  3. mands72
    Dec 1, 2014
    Please add support for IPv6, it would fix so many issues on my sites related to IPv6... I still don't understand what's the technical problem or limitation not to support IPv6 on the 3CX phone system.
