Is 3CX compatible with OOMA.com
Discussion in '3CX Phone System - General' started by dangraves, May 9, 2008.
  1. dangraves
    May 9, 2008
    I would love to start using this product, but I am not sure if it is compatible with http://www.ooma.com . It is a VOIP service with no monthly costs
    If someone could please let me know that would be great!
    Dan
  2. coelhopsi
    May 7, 2008
    84
    Dan,
    OOMA.com is not compatible with 3CX. OOMA uses a proprietary technology, incompatible with SIP, which is the protocol used as standard not only by 3CX but also by many VoIP providers and vendors.
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    Dan,
    How do you like ooma? How long have you been using it? I read about it some time ago and when I saw how they were intending to make use of their clients' PSTN lines to route calls, I was alarmed. Are you letting them use your PSTN line? Do you get connected consistently?
    Thanks for your feedback.
    Halea
