is 3cxphone support IAX extension
Discussion in 'iOS' started by janiali, Jul 11, 2012.
  1. janiali
    Jul 11, 2012
    Dear All,
    can some one tell me if 3CXphone for iphone support IAX extension ? I need to register an IAX extension but could not found any way to do it
    thanks in advance
    11,115
    329
    No, IAX http://en.wikipedia.org/wiki/Inter-Asterisk_eXchange is not SIP http://en.wikipedia.org/wiki/Session_Initiation_Protocol.
    The 3CX Phone is a SIP device.
  3. StefanW
    Jun 2, 2009
    1,222
    93
    as already right answered, AIX is a propriety type of sip for asterisk servers (asterisk inter-exchange protocol).
    We as 3cx are based on RFC-SIP. Our AIX is called 3CX Tunnel (has some more advantages then AIX) but only works for a 3CX Phone System. Maybe it would be good to check out the 3CX PBX it self!
