is a proxy server?
Discussion in '3CX Phone System - General' started by cristina, May 6, 2008.
  1. cristina
    Apr 23, 2008
    12
    Hi, I need to know if 3cx works just as a proxy server or if it works as a back to back user agent.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It is neither proxy nor b2b. It's a suite of components which form SIP based IP PBX.
