is extension logged in to queue ?
Discussion in 'Call Flow Designer' started by mirjam.nz, Sep 25, 2017.
  1. mirjam.nz
    Dec 6, 2010
    28
    Hi all
    I try to find out if a specific extension is logged in to a queue via CFD.
    Following the thread "Find amount of available Call Queue agents" was leading me into the right direction and was very helpful, but I'm not quite there yet.
    In the queue log I do get the information which extensions are logged in and also its state, but I can not retrieve this in the code.
    Any help appreciated.
    Cheers
    Miriam
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,056
    75
    Hi @mirjam.nz,
    In the final release of the CFD we have included a new component named "Get Queue Extensions", which will give you that information. Here you have information about that component:
    https://www.3cx.com/docs/manual/cfd-components
    In that component you specify the queue extension number, and the state you need, for example Logged In, and then it will return a list of extensions logged in to that queue. You can iterate the list returned to check if a specific extension is there or not.
    However, you can still use the code you created if you prefer. In that case, let me know what the problem is, so I can help you out. Your code can return a single value, so if you need to return many things at the same time you can use a struct or class to do it...
    Kind regards.
  3. mirjam.nz
    Dec 6, 2010
    28
    Thanks Ernesto
    It would be extremely helpful if you could give me a quick examples on how to retrieve this.
    I have tried TcxGetQueueExtensions1 and then log it, but the output remains empty. Why? A example here would be much appreciated.
  4. mirjam.nz
    Dec 6, 2010
    28
    I find the below in the CFD component documentation under "Get Queue Extensions configuration", but I do not understand how to use it.
    Quote: "In order to get the values from the resulting lists, we need to use the following CFD Functions:
    • GET_LIST_ITEM_COUNT: this function will give us the number of items in the list.
    • GET_LIST_ITEM: this function will return the item at a specific index."
  5. edossantos
    Jun 27, 2007
    1,056
    75
    Hi @mirjam.nz,
    Exactly, the output properties (return values) for component "Get Queue Extensions" are lists. If you try to log them directly, you will not see the items inside. What you need to do is using functions GET_LIST_ITEM_COUNT and GET_LIST_ITEM to get the values you need. For example, if you need to know how many extensions were returned you use the following expression which will return that number:
    GET_LIST_ITEM_COUNT(TcxGetQueueExtensions1.ExtensionNumberList)
    So now let's say that you have 3 elements in that list, in order to get the extension numbers you can use the following expressions:
    GET_LIST_ITEM(TcxGetQueueExtensions1.ExtensionNumberList, 0)
    GET_LIST_ITEM(TcxGetQueueExtensions1.ExtensionNumberList, 1)
    GET_LIST_ITEM(TcxGetQueueExtensions1.ExtensionNumberList, 2)
    Kind regards.
