Is Fanvil X3S is not supported by 3CX
Discussion in '3CX Phone System - General' started by aslampa, Jan 31, 2017.
  1. aslampa
    Mar 18, 2016
    44
    We bought ne Fanvil X3S IP phone and it works fine with the system but 3CX Phone system console it shows not supported. Anyone knows why [​IMG]
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
  3. aslampa
    Mar 18, 2016
    44
    Thanks for your response. I will upgrade the firmware and see how it works.
  4. aslampa
    Mar 18, 2016
    44
    Do we need to use the exact same Firmware. I have upgraded the firmware but still shows the same
  5. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Yes you need to use the supported firmware shown in the updates section of the management console or else you will get that message
  6. aslampa
    Mar 18, 2016
    44
    Could you please help me to get the correct firmware since I could not able to find it online.
  7. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Here you are.
    You can download it by clicking on the updates section in the management console.
