Is inbound call block available in 3CX present release?
Discussion in '3CX Phone System - General' started by Mirzab, Jul 26, 2007.
  1. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Can anyone advise me if the present release has option for inbound call block at the server level? Possibly based on a specific Caller ID and/or all blocked IDs? If not, is this option being considered in the near future? I use PAP2s to support the analog extensions on traditional lines and a couple of softphones as a test, and would like to block certain callers in total.
    I have been using this software only for a couple of weeks but already it has replaced the old hardware switch in my home. I am very impressed. Great job so far. Even better price! Thanks.
  2. gbarnes
    Aug 3, 2007
    83
    work around
    I too would like this function, and wonder if there is a workaround for it, even if I have to hard code a number. Like a Outgoing Call Rule, but for incomming number.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Mirzab,
    No such function at current version 3CX Phone System v3.1.2434.0. This function should be done by the client not at the PBX side.
    Regards,
    5Q
  4. gbarnes
    Aug 3, 2007
    83
    Workaround time...
    a workaround.. EDIT: See my new way below.
    Graeme
  5. gbarnes
    Aug 3, 2007
    83
    Dont moan!
    :shock:
    Oh, and before you do this, you had better back up the files you changed. And dont moan at me, its a nasty workaround for those who REALLY need the above function. But sometimes we dont like unknown callers do we. No.
  6. gbarnes
    Aug 3, 2007
    83
    My new way...
    This is my new way, that allows you to block incomming calls or divert them to a different DR..
    Edit the ivr_start.php file then find :
    // Menu ID
    if( is_null($rp_dn) )
    $rp_dn = $rp_IVRHandlerMENU;
    $rp_dn = $rp_IVRHandlerTO;
    // Then ADD this bit BELOW :
    if ( $rp_caller == "02071626253" )
    $rp_dn="899";
    This will BLOCK caller (ie DR 899 does not exist!)
    Or use $rp_dn="803";
    for example to send that call to DR 803..
    You can add in more
    if ( $rp_caller == "103" ) // CALLER ID NUMBER
    $rp_dn="802"; // DR TO DIVERT TO
    bits after to add new 'rules' to this method. Much easier than the above method.
    A good use for this is to send 'family' calls straight to your extension via a dummy DR,
  7. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    You need to get 3CX to put you on the payroll :lol:
    Thanks, I will try.
  8. gbarnes
    Aug 3, 2007
    83
    Unknown...
    Use the bit below to block or divert UNKNOWN calls to a DR message saying "Unblock your number, you MONSTER!", eg:
    if ( $rp_caller == "Unknown" ) // CALLER ID NUMBER
    $rp_dn="877"; // DR TO DIVERT TO - SAYS "UNBLOCK NUMBER!!"
    Its always useful!
    Graeme.
