Is it possible to change DID routing with CFD?
Discussion in 'Call Flow Designer' started by infohit, Mar 7, 2018.
  1. infohit
    Nov 21, 2017
    21
    8
    As the title says, I'm wondering if it's possible to use Call Flow Designer to change in-office or out-of-office routing for a specific DID? And if it is, how can I do that? :)
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,602
    125
  3. Michael Groom
    Dec 11, 2017
    63
    Still working on a solution
