Is it possible to disable Remote Extensions?
Discussion in '3CX Phone System - General' started by garethb_83, Jun 3, 2010.
  1. garethb_83
    Oct 11, 2007
    25
    Is it possible to disable Remote Extensions? Or someway bind extensions to only be allowed to be registered from an IP address within the same subnet?
    11,095
    327
    Are you talking about a remote that is the duplicate of a local extension? Is it someone taking their set/ATA home with them, at times, to use?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    What is the purpose to do it for the authorized users? Could you please describe "business/use" case?
    "Firewall" provides you with ability to filter traffic, doesn't it?
