Is it possible to install 3cx onto a virtual server?
Discussion in '3CX Phone System - General' started by rewing, Oct 17, 2007.
  1. rewing
    Sep 1, 2007
    25
    Since 3cx phone system are based on web configuration. I wonder if it can be run on a virtual server like ixwebhosting. because it provide dedicate IP address for domains.
    any one ever tried ang got it work?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Well , i dont know if its the same thing, but i know you can run 3cx on VMware, a software that creates virtual machines. So my guess is.. yes....
    Cheers
  3. BendyMetal
    Oct 8, 2007
    36
    I doubt you could actually get the whole of 3cx to work on this particular service - by the looks of the website, they aren't giving you access to a virtualised server, more just a web hosting environment. I suppose theoretically you could host the db and php parts on that....but in reality that might get complicated. Let us know how you get on if you proceed.
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I believe they mean Virtual PC, Virtual Server or VMWare.
    Virtual PC is free from Microsoft. I was going to give it a try with Virtual Server on a new server box I'm building just to test it out.
  5. BendyMetal
    Oct 8, 2007
    36
    I see absolutely no reason why 3cx wouldn't run in a virtualised environment.....i stand to be corrected however.... ;-)
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    I cannot even imagine, how PBX can be based on web or any other configuration :)
  7. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    It could be possible if SIP was changed to use port 80 only with a database backend. Someday we may see this but I doubt it will be anytime soon.
  8. rewing
    Sep 1, 2007
    25
    hey,guys!
    I don't mean to install it on a virtual PC, but onto a web hosting! Some webhosting could provide full privilege to access the hosting. But you can't using GUI installation process. what we could do is to : copy all files that have been installed in our local PC to hosting. and then using Shell to register and run services that needed for pbx phone system.
    I guess it's possible, but I don't know how to process it. it may need us to write some .bat file to manual start the service.
    The idea is that if you could copy the installed folder to another PC and manual start all service , you may be able to do it in a hosting space.
    Anybody ever try?
  9. BendyMetal
    Oct 8, 2007
    36
    sorry to break this too you, but that ain't gonna work!!
  10. LORD ORION
    Jul 23, 2007
    39
    Not to be a weenie, but a word of caution is required here.
    Alot of telephony doesn't work using virtualization.
    3cx may work, but this does not mean everything else in your infrastructure will.
    The main problem being that virtual ports are created when using virtualization, which adds a layer of abstraction away from the real hardware/software.
    This becomes problematic in the TDM world, as the timers are going through a layer of virtualization that you don't see. This can have a very bad effect on quality or even outright fail.
    eg: Some telephony software makes use of APIC timers on the motherboard for timing (because it is very precise)... this is an automatic failure guarantee when using virtualization, as the APIC timer is suddenly not so precise when going through the added virtual layer.
  11. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    3cx also installs as windows services. A web host will not let you add services to their servers.
    My new server is almost up and running (formating the drives as I type). I'm going to try Virtual PC and see how 3CX works. I'll do a full review when it's done.
  12. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Dont know about Virtual PC, but i can tell you thoug that it works in VMware, i tried this myself and had no problems.
    CHeers
  13. jimmy
    Oct 21, 2007
    I'm running this on vmware too, as my spare pc already is being used as a linux router. :)
    Good system imho, i like it 8)
  14. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I'm still using 3cx on microsoft virtual server.
    Is running on a sbs 2003 server vhd image. Works Perfect.
  15. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    I think this poster meant if it will work on a virtual web host... The answer is no, a virtual web host is only for websites. We've managed to pass that stage of development luckily :)
    It requires Windows. It can run fine on a virtual windows, although not as performant as running directly on a machine. That said for smaller installs it does not make a difference. We run our 25 extension system on a Virtual Machine with XP and 512 meg memory. I'd say from 5-10 simultaneous calls onwards it might be better to install it directly on the host.
