is it possible to run multiple accounts at the same time
Discussion in 'Android' started by malhyp, Mar 2, 2012.
  1. malhyp
    Mar 2, 2012
    HI there, I have installed the latest version and installed it on the latest HTC Widlfire S and have setup 4 phone numbers. I noticed that when I have one of the phone numbers set as default that I can not call the other numbers, it seems that it will only allow me to actively use one phone number to receive calls.
    I notice that there are many settings but dont understand what they are all for.
    Is it possible to have it so that the 4 numbers can receive calls, im happy to call out from one default number.
    Cheers
    Malcolm
    11,277
    360
    You can only have one profile active at a time.
