Is it possible ?
Discussion in '3CX Phone System - General' started by miraportuga, Aug 24, 2007.
  1. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Been looking on the internet and havent found anything yet... wonder if its possible to transfer a call from the phone connected to SPA3102 by dialing for example *200 to another of my extensions. If so, how do i can transfer a call ? from that phone to any other extension.
    Thk u
  2. Anonymous
    Anonymous Guest
    Having a phone connected to the SPA and than use this phone to dial any extension on the 3CX?
    Is that is what you want to do?
  3. june
    Aug 24, 2007
    I think it's possiball,but i had never try it!ha ha ha ....
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Ill try to be more clear now.
    Lets imagine, i pickup a call on the phone that is connected to the SPA, then i want to transfer this call to another extension, can i do that ? is that possible using a combination (for example to extension 100) **100?
    Is this possible ?
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Yes
    Press Flash Key
    then *98
    then the ext. numbre
  6. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Thank you :D
    Its working now :D
