Is port restricted cone ok to use on 3cx ?
Discussion in '3CX Phone System - General' started by commplete, Jun 24, 2008.
  1. commplete
    Feb 29, 2008
    17
    Hello
    I have checked with our supplier and it seems that our router (Draytek 2820) is a port restricted cone router.
    I see that the 3CX requires full cone. Is port restricted cone also suitable ?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It may work in many cases, but we can not guarantee 100% reliable work.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi commplete,
    We have already tested following Draytek 2200E+, 2910, 2950 and 5510 are works fine for NAT. Except we blocked the ports which use by SIP.
