Is posible Call hunting with SIP?
Discussion in '3CX Phone System - General' started by juanky, May 18, 2007.
  1. juanky
    May 14, 2007
    28
    After reading and searching I'm not sure if Call Hunting is possible with Sip or using 3CX PBX Systems...
    Is it able?? How??
    Thanks in advance.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Ring group in "Hunt" mode, but it works only with extensions.
    Regards,
    Stepan
  3. Anonymous
    Anonymous Guest
    Like sy said, it works with extensions.
    You can (alternative) give each extension an external number to dial, and make that extension part of the hunt group.
    So if your external number are other sip/did numbers you might work arround it that way.
    That should work in theory....... :)
  4. juanky
    May 14, 2007
    28
    I see...but it doesn't look a real "call hunt" since you must wait your extension rings...
    I'll try it, anyway..
    Thanks.
