Is someone trying to connect to my PBX?
Discussion in '3CX Phone System - General' started by hainesk967, May 31, 2011.
  1. hainesk967
    May 23, 2011
    38
    I saw this in my Server Activity Log and am confused by it. I am not using Asterisk PBX, and the ip address traces back to a onestop.net cloud server. What does this mean? Any help will be appreciated!
    11:09:49.295 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:9011442070661000@71.236.202.97 SIP/2.0
    Via: SIP/2.0/UDP 74.208.238.66:36967;branch=z123RE8gBkor3;rport=36967
    Max-Forwards: 70
    Contact: <sip:asterisk@74.208.238.66>
    To: <sip:9011442070661000@71.236.202.97>
    From: "asterisk"<sip:asterisk@74.208.238.66>;tag=z321RE8gBkor3
    Call-ID: abc124836edfb@74.208.238.66
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
    Supported: replaces
    User-Agent: Asterisk PBX
    Content-Length: 0
  2. hainesk967
    May 23, 2011
    38
    I suppose someone might just be calling me from an Asterisk PBX? Is this what it would look like? Do I need to adjust my incoming call rules to accept these?
  3. Cjay
    Cjay New Member
    Feb 24, 2007
    199
    More likely someone is trying to take advantage of your PBX hospitality. The number they are attempting to call is interesting since it is made up of the US IDD code (011) and then a UK number which is for the Financial services Authority. Unless you know that this is a legitimate remote extensions then this is probably a probe to see if your PBX can be used to make free calls. Are you running a firewall?
  4. hainesk967
    May 23, 2011
    38
    Yes I am using a firewall and the only port that is forwarded to my server is 5060. I think that to dial the UK from the US you have to use 011+44. I didn't notice the number involved. It looks like it didn't go through anyway. Is there anyway to stop this from happening or will I just notice this from time to time?
  5. Cjay
    Cjay New Member
    Feb 24, 2007
    199
    On my firewall I block everything targeting port 5060 except packets coming from the known IP's of my VOIP providers. As I only have 2 providers this is easily done.
  6. hainesk967
    May 23, 2011
    38
    Ok, thanks a lot for the help!
  7. leejor
    11,095
    327
    I had one of those last night, same phone number (without the leading 9), which I looked up this morning. Will have to have a look and see if it came from the same IP as yours. (the attempt on mine came from 173.237.189.70 which translates to ..ajax.vivawebhost.com ) Someone is up to no good, i suspect....
  8. hainesk967
    May 23, 2011
    38
    Hey,
    How do I go back further in my server activity log to check for any other instances of this happening?
  9. leejor
    11,095
    327
    http://www.3cx.com/forums/server-activity-log-historic-log-files-where-are-they-19768.html
  10. hainesk967
    May 23, 2011
    38
    Since I'm using server 2008, that doesn't help....
  11. hainesk967
    May 23, 2011
    38
    FYI: I was able to find it under c:\programdata\3cx\data\logs\3cxphonesystem.log
    All dates are apparently combined into that one file.
  12. voipbaennjer
    Jul 10, 2009
    44
    @ Cjay
    I get those attempts also once in a while. 3CX so fare had blocked all of them. What firewall do you use where you can block all traffic except the one coming from your VOIP provider??
  13. leejor
    11,095
    327
    I'm seeing that every once in a while too. Obviously from the same source as the phone number they are trying to "test" to is only slightly different. It's coming from various IP's in "bursts" of 5 or 6 "probes
