Is the fax service running at all?
Discussion in '3CX Phone System - General' started by jacky18, Jul 31, 2008.
  1. jacky18
    Feb 16, 2008
    16
    Hi I wonder if the Fax Service can be used at all? In the server status, it shows it's running however, I don't seems to be able to configure it (or maybe I'm just too green to find out how).
    On the other hand, if this service is not usable, is there a way to turn it off?
    Thanks.
  2. Anonymous
    Anonymous Guest
    What are you trying to configure?
    From a line, you must set all calls as faxes in order for fax service to kick in.
    Thanks,
  3. jacky18
    Feb 16, 2008
    16
    The reason I asked is that I'm running a community version and I kept seeing the fax service running. Just wonder if I can use it or not because if not mistaken, receiving fax is a paid feature.
    If it's a paid feature, then I want to stop this feature as I'm using community version and fax is also taking a bit of resources :)
  4. Anonymous
    Anonymous Guest
    Yes, receiving faxes is for the commerical versions only, so in your case you can disable it.
    Thanks,
