is there a Barge In dial code?
Discussion in '3CX Phone System - General' started by vsefcik, Dec 15, 2009.
  1. vsefcik
    Nov 18, 2009
    19
    I'm using 3CX version 8.0.10116 and can "Barge In" to an existing call using 3CX Assistant 8.0.9924. Is there a 3CX Dial Code that I can use from another extension to "Barge In", or can this only be done via 3CX Assistant?
  2. Lukas
    Jan 23, 2011
    45
    This question has nevever been replied to... is the answer a "no"?
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    No dial code - just the assistant.
    The problem with dial codes for everything is that they are not easy to remember them all and you soon run out or 3cx will get confused with other codes.
