is there a known problem with the new 3cx
Discussion in '3CX Phone System - General' started by spec, Feb 25, 2007.
  1. spec
    Sep 8, 2006
    51
    I had not updated for 3 months but it was working. I have now downloaded and installed the latest 3cx to find the 3 voip providers will no longer work.
    The first thing I tried was to use the backup file to reconfigure the 3cx as that didn
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Please send us a screen shot of the voip providers configuration page, a sceen shot of the lines under each voip providers to see how you configured them and finally the PBX build (version) you are using. (you can see the build by going to server status.) You can send this to support@3cx.com
