Is there a limit to number of BLF keys?
Discussion in '3CX Phone System - General' started by that1guy, Sep 6, 2017.
  1. that1guy
    Jul 27, 2017
    48
    Greetings,
    I am using Yealink T41s, 3cx v15. I was curious as to what the limit of BLF keys was. I am working with a client using well over 40 extensions with DIDs and they wanted speed dial setup for each extension. I didn't want to tell them I could add 40+ exts with out being more informed.
    Thanks!
  2. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    Max 15 for that phone. According to the template. The phone swaps pages so it has 6 keys and 3 pages with next button.
    Seems it cannot take an expansion module.
    I think for this phone you need a more high-end model.
    You need one of these with expansion modules...
    https://www.3cx.com/sip-phones/yealink-t5-series/
  3. that1guy
    Jul 27, 2017
    48
    Thanks for your response!
  4. neville
    neville New Member
    Apr 23, 2012
    208
    34
    We use the windows client frequently for this. With the PRO, the users can configured their own BLF. They can configure up to 3 sidecars with I think 36 keys on each for a total of 108 BLF's. If you go beyond that or use Standard, you will have to add them in the management console.
  5. that1guy
    Jul 27, 2017
    48
    My client prefers not to use the windows client. Thank you for the suggestion tho. Im sure I can put this info to good use.
