Is there a list of 3CX recommended ATA adapters ?
Discussion in '3CX Phone System - General' started by Fatboy40, Sep 15, 2010.
  1. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    I'd like to hook up a couple of analogue lines, in the UK, to our new 3CX v9 system. There are various ATA adapters out there, however, it doesn't appear that 3CX officialy reccomend or support any specific manufacturer or model ?.
    Which out of the following would people reccomend to use with 3CX v9 ?...
    Linksys SPA3102 Analog Telephone Adapter
    Patton M-ATA-1/E Micro Analog Telephone Adapter
    ... thanks.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    We successfully use the Linksys PAP2T with 3cx and we have SPA3102.
    Havent used the Patton so cannot comment on those.
    For just analog phone use then you cannot go wrong with the PAP2T. We have a lot of customers who plug in 2 DECT6 phones in them and all of them comment on the high call quality since moving from traditional phone systems to VOIP.
  3. leejor
    10,374
    231
    If you go to ... http://www.3cx.com/support/ you will see the configuration guides and which devices have been tested. It would certainly be my understanding that if a device were listed there then that would be a sort of recommendation, wouldn't it?
    The two devices you mentioned, the Patton and the Linksys are slightly different, in that that Patton is only an ATA whereas that Linksys is both an ATA and a Gateway.
    Many devices seem to perform the same function, however, some lack additional functions/flexibility that you won't notice missing until you "get into" VoIP a bit more. I wouldn't go out and buy a dozen of one particular device unless, you were already familiar with it, and liked it, or, it was highly recommended by someone you trust, and you got a great deal on them.
    You do get what you pay for, shop around. Buy one or two, try them out, find out what they can or can't do. If you really like them, and they do what you want, then buy more, otherwise move on to another device.
  4. Eurylink
    Eurylink New Member
    May 25, 2008
    174
    Many ATA can work with 3CX. Grandstream 286, 386 but also multiport 4004-4008-4024 are fully supported and work great with 3CX. Linksys SPA-2102 (2 port) work great too. If you prefer Patton All FXS multiport (4,8, 24 FXS) can work without problem with 3CX (but the configuration is not simple like for Grandstream and Linksys).
  5. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    I wasn't aware that the Linksys SPA3102 was a gateway as well !.
    That's me buying one today then, thanks everyone :)
  6. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    ... well, three purchased actualy, which should keep me busy for a while :wouldliketoaddasmiliebuttheydontwork:
  7. raqdedicados
    Dec 5, 2010
    linksys pap2t extesion
    Hi there
    Can someone please can explain me how to configure the pap2t as an extension for the 3cx pbx. i'm very newbie to this and trying to setup it but it always fail, the extesion register but i can t make the phone ring and etc...
    Also it is possible to configure the other pap2t extesion as a fax ext ?
    I would appreciate if someone could help me with this
    Thanks a lot !
