is there a required network switch for the ip phones?
Discussion in '3CX Phone System - General' started by jerryl, Sep 20, 2011.
  1. jerryl
    Aug 31, 2011
    7
    Hi guys i just want to ask if there is a required network switch to use the ip phone? our company is decide to this network switch, HP E2520-8G-PoE Switch. can we used this?or there is another supported product that we can install. we'll just used this for the network for us to connect the ip phones that we are using.
    thanks,
    jerry
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    Generally makes no difference what brand / model switch you are using.
    In a heavy usage environment you should take care about QoS, possible bottlenecks, etc.
    Using separate VLANs for voice and data may also be considered.
    Regards.
  3. jerryl
    Aug 31, 2011
    7
    thanks for the advice..peace out\m/ ;)
