is there a way to change the default extension setup?
Discussion in '3CX Phone System - General' started by alexmallia, Sep 4, 2008.
  1. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    The defaults are fixed and cannot be modified.
    However you may sumit this as a feature request forum post.
    regards
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Feature request done
    http://www.3cx.com/forums/add-new-ext-6636.html
    please support it to take 3CX team care
