Is there a way to choose which ext show in "Extensions Up" dashboard?
Discussion in '3CX Phone System - General' started by netelligence, Oct 12, 2016.
  1. netelligence
    Sep 24, 2012
    30
    Because some of the desired features need to use "dummy" extensions, is there a way to not have the dashboard count those extension in the "Extensions Up"?
    For example if I have 2 "dummy" extensions that phones will never use to register out of 10 extensions. Then I'd like the "Extensions Up" to show 8/8 extensions rather than 8/10 since 2 of those will never be "up".
    Thanks,
    Netelligence
  2. nb
    nb Support Team
    Jun 7, 2007
    2,128
    152
    We will not have this. 3CX has no idea of an extension is a "dummy" or not.
  3. IT Hamster
    May 21, 2015
    43
    You will need to use "Extension Groups" and then modify those group rights to display to "all company".
    I've done this in a few use cases- primarily for hiding phone activity of Executive and HR staff from general viewing.
    Play around with adding your "dummy extensions" to their own extension group and then set the group rights to not show their activity or presence.
