Is there a way to do phone number formatting for the U.S.
Discussion in '3CX Phone System - General' started by Ouray RV Park Cabins, Apr 15, 2017.
  1. Ouray RV Park Cabins
    Apr 3, 2017
    16
    I just cant seem to find a good doc / example on how to reconfigure the Caller ID information being passed from: xxxxxxxxxx to: (xxx) xxx-xxxx
    I know I need to edit the Trunk Editor Inbound and Outbound, but I just cant find a good U.S.example.
    Thanks!!
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    May I ask why ?? How would someone redial ? (Cause obviously when you call out you can't send the telco those ()- characters )
  3. leejor
    10,744
    281
    Dashes and spaces (on the numeric portion of CID) are normally inserted by the receiving device.
  4. Ouray RV Park Cabins
    Apr 3, 2017
    16
    Thanks for clearing that up, I was asking the wrong question.
    Then is there a way to configure the softphobe 3CX client and my Yealink devices to display the format (xxx) xxx-xxxx? This is the format that the cellular carriers and even Google Voice shows when calls are received.
  5. leejor
    10,744
    281
    It's whow the device you are using, formats the number. There may be a Yealink feature that allows this. Many mobiles will do this for numbers, in the format used, for the country the the set was originally issued in.
