Is there a way to terminate a call from the server?
Discussion in '3CX Phone System - General' started by Ralph, Jul 27, 2007.
  1. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Lets say you need to terminate a call from the server. Is there a way to do this?
    Thanks again
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Restart "3CX PhoneSystem" service at your server.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If you will restart 3CX PhoneSystem, then you need to restart "3CX PhoneSystem Media Server" as well if there were active calls.
    You may use CA to drop calls related to extension.
    DR will drop calls after timeout.
    Why do you need to drop those calls?
  4. Ralph
    Ralph Member
    Jun 28, 2007
    417
    I had a situation where a call remained active even after the parties hung up. I think it had to do with one of them being on a wireless phone that was out of range of the base station and having dialed the 3cx pbx instead of an outside number by mistake. Anyhow, things happen and it would be good to have a way to take care of this without having to restart the entire server.
