is there any 1 port FXO gateway someone can really recommend
Discussion in '3CX Phone System - General' started by justin, Aug 2, 2008.
  1. justin
    Feb 20, 2008
    79
    I use the SPA3102 and so do many on here and it's pretty cheap :)
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    I agree with justin
    the only bad think I can say is the calls between fxs and fxo is not the same quality like between fxs and fxs which is very clear and in my openion its more clean than analog pbx
    may be I did something rong in pstn configuration
  3. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    justin and amygoda,
    Are either of you in the US? If so, can you send your configs for the SPA-3102? I have been struggling with one for a long time. Can't seem to get decent voice quality.
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hi Dyntech
    can you explan more the bad voice you got ?
    Is it in pstn use or in fxs use?
  5. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    When I used my Cisco7960 to receive calls from the SPA-3102 I would get an echo and gargled audio of my own voice. The other person did not get it. I changed all of the settings and enabled and disabled echo cancellation and nothing helped.
    Since I have been using it recently, I created a separate voice VLAN on my switch and that seems to have helped some but I still get it sometimes.
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    did you try
    SPA to PSTN Gain = ?
    PSTN to SPA Gain = ?
  7. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Yes, tried different levels on both even negative values. They did change the volume both not much help with the echo.
  8. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Set codecs periority to g729
    what is your server specs
  9. moon1234
    Jan 25, 2008
    24
    I have been using the Zoom 5801 and it works very well. There is NO echo at all. There are a LOT of options in the user interface and that can make it a little confusing for those not at least a little familiar with SIP and PSTN terminology. Once you get it setup and working it is a solid device.
  10. moon1234
    Jan 25, 2008
    24
    Just because it is not officially supported does not not mean it is not a good device. 3CX can only test and certify so many devices. The Zoom 5801 is an inexpensive model that is geared towards VoIP providers. Zoom made the device available to enterpise customers, but have left most of the configuration up to the end user. Zoom is VERY good when it comes to helping you with any bugs you may find.
  11. francesco
    francesco New Member
    Jun 23, 2008
    102
    i use grandstream 486 and is good for home use
  12. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Matt, you need NOT Grandstream ATA 486 but Grandstream ATA 488 http://www.grandstream.com/ht488.html
  13. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    HT 503 is the latest and has caller id
  14. igor.snezhko
    Jan 7, 2008
    668
    7
    Yes you are right! The HT 503 is latest 1 FXO model.
