Is there anyway to detect which IVR option was selected?
Discussion in 'CRM / Helpdesk / App Integration' started by martinpluss, Dec 2, 2011.
  1. martinpluss
    Jun 28, 2011
    30
    I want to create a simple VAD project that plays a wav file depending on which Option was chosen from an IVR. Is there anyway of me detecting which button was pressed or do I have to add the IVR into the VAD project too?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    This should be quite simple using conditional statement and playing different files in branches.
    Regards
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Do you have a Digital Receptionist IVR first, and then you transfer the call to the VAD? If that is your case, the only way to know what option was selected is transferring to a different extension, and register the VAD in all those extensions. But this way you need to deploy your VAD project many times to different extensions.
    I suggest putting the menu into the VAD, and then play the desired message into each branch.
    Regards,
  4. martinpluss
    Jun 28, 2011
    30
    Thanks guys. I'll build it all into the project as suggested.
