is this really work? cant login to operators
Discussion in '3CX Phone System - General' started by Anonymous, Dec 24, 2006.
  1. Anonymous
    Anonymous Guest
    i write
    External Number (PSTN line number, e.g. 22461000): 48673499054
    password
    Proxy Hostname or IP: sip.actio.pl
    Proxy Port (default is 5060): 5060
    Time between registration attemps (in seconds) 360
    Stun server Hostname or IP: stun.halonet.pl
    Stun server Port (default is 3478): 3478
    every program, and router can login but this phone system dont
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    VOIP provider
    Thank you for your feedback.
    Please post your server status log and we can review it. however it could very well be that the current version is not compatible with this particular VOIP provider.
  3. Anonymous
    Anonymous Guest
    14:15:48.031 ??: SL: connected komp0:0/PHPExtension_0 at [komp0]/PHPExtension_0
    14:15:28.343 SessionMgr::thread: ** Entering Main Loop **
    14:15:28.343 SessionMgr::run: ** Start Session Manager **
    14:15:28.296 SessionMgr::run: ** Initialize Status Monitor **
    14:15:28.296 LineImpl::update: Line: register line ztest
    14:15:28.250 LineImpl::update: Line: register line 48673499054
    14:15:27.968 DBA: ** Database connection Ok **
    14:15:25.500 SessionMgr::run: ** Initialize Lines Manager **
    14:15:25.500 SessionMgr::run: STUN hasn't been able to resolve external IP!
    14:15:22.500 SessionMgr::run: ** Initialize Client Authentication **
    14:15:22.500 SessionMgr::run: ** Initialize Server Authentication **
    14:15:22.500 SessionMgr::run: ** Initialize DUM **
    14:15:21.734 SessionMgr::run: Can not resolve IP address of STUN server (stun.3cx.com)
    14:15:09.093 MediaServerConnected: Media Server is connected
    14:15:09.093 ??: SL: connected komp0:0/MediaServer at [komp0]/MediaServer
    14:15:04.093 SessionMgr::run: ** Adding transports **
    14:15:04.062 SessionMgr::run: Version: 2.0.913.0
  4. Anonymous
    Anonymous Guest
    without stun.halonet.pl
    17:34:49.390 ??: SL: connected komp0:0/PHPExtension_0 at [komp0]/PHPExtension_0
    17:01:51.406 SessionMgr::thread: ** Entering Main Loop **
    17:01:51.390 SessionMgr::run: ** Start Session Manager **
    17:01:51.265 SessionMgr::run: ** Initialize Status Monitor **
    17:01:51.250 LineImpl::update: Line: register line ztest
    17:01:51.140 LineImpl::update: Line: register line 48673499054
    17:01:50.328 DBA: ** Database connection Ok **
    17:01:48.703 SessionMgr::run: ** Initialize Lines Manager **
    17:01:48.703 SessionMgr::run: STUN resolved external IP: 86.63.93.165
    17:01:48.687 SessionMgr::run: ** Initialize Client Authentication **
    17:01:48.687 SessionMgr::run: ** Initialize Server Authentication **
    17:01:48.687 SessionMgr::run: ** Initialize DUM **
    17:01:47.734 MediaServerConnected: Media Server is connected
    17:01:47.734 ??: SL: connected komp0:0/MediaServer at [komp0]/MediaServer
    17:01:45.484 SessionMgr::run: ** Adding transports **
    17:01:45.437 SessionMgr::run: Version: 2.0.913.0
  5. Anonymous
    Anonymous Guest
    i think this program is realy not work
    its only for payable user works
    its nice to see, but i must try asterisk
    maybe that will works
